200609 error on upgrade from PCMCIA 6036-E USB 6212-M
Unfortunately I am more of a "power-user" than a developer, so I may have to research the answer to your question.  However, I can tell you the encoder is an "incremental" type that has an "A-Phase" and a "B-phase" output.  And comparing the 6036-E PCMCIA pinout diagram against the 6212-USB shows both use common connections.  Encoder phase A is the only possible exception (see table below).
Also, from what I can tell, it does look like my encoder is a quadrature encoder (picture below), I'm just not 100% on what type it is (X1, X2, X4).
 Encoder Phase A-Encoder phase B-Encoder phase A +Encoder phase B+
Cable PIN #7133716
6036 E PCMCIA PinoutD GNDD GNDPFI 8 / CTR 0 SRCP0.6
6212 M USB PinoutD GNDD GNDPFI 8 / P2.0P0.6
Does it matter that the 6212 doesn't reference CTR0 on pin 37 while the 6036 does?
Do I need to physically re-wire something for this encoder to increment/decrement with the 6212-USB?
Any insight would be greatly appreciated.
Message 11 of 14
(2,208 Views)
Accepted by topic author hma1
Hi hma1,
The USB-6212 doesn't support using P0.6 and P0.7 as direction terminals for edge counting. You'll have to wire your encoder's B signal to a PFI terminal instead. In the DAQ Assistant, the direction terminals for the USB-6212 are PFI10 for ctr0 and PFI11 for ctr1.
Brad
Brad Keryan
NI R&D
Message 12 of 14
(2,191 Views)
Brad,
Thanks a lot for your excellent advice.  I wired up the encoder the way you suggested and the counter increments and decrements correctly now!  I will let you know what the results of the first test look like.
Thanks again for your helpfulness,
Adam
Message 13 of 14
(2,173 Views)
The results of the first testing looked good.  Thanks again to everyone for all your support.
Message 14 of 14
(2,123 Views)
