32-bit DAQmx library for 64-bit Linux
I have a 32 bit application that I need to link with libnidaqmx.so. All the downloads I could find were for 64 bit versions of this library. Does there exist a 32 bit version of this library that supports RHEL 8? My operating system is 64 bit.
(1,189 Views)
Excerpt from NI-DAQmx 2023 Q3 for Linux/x86 64-bit Architecture Readme
NI-DAQmx requires a 64-bit distribution and does not support 32-bit applications
https://tmesystems.net/
(1,162 Views)
NI stopped supporting 32-bit application development for LabVIEW for Linux somewhere in the 2017 timeframe. I would guess that is also the time they discontinued support for 32-bit drivers. Redhat 8 having its first release on 2019-05-07 is likely not supported by DAQmx before 2020.
Rolf Kalbermatter  My Blog
(1,123 Views)
Thanks. Are there 32 bit libraries available for RHEL 7 then?
(1,112 Views)
NI-DAQmx Base supports 32-bit Linux. See Programming Data Acquisition for Linux with NI-DAQmx Base
NI-DAQmx Base Download
(1,108 Views)
