4 wire resistance measurement using Compact DAQ - How to connect?
Sir
Is it possible to use DAQ Assistant for cRIO-9025 with NI 9219.
If possible please reply with the steps to be followed. I m using Measurement & Automation explorer of version 5.3.1fo.
Nripen k.
Message 11 of 12
(953 Views)
I have a NI9219 in Compact DAQ 4slots USB and i want to measure a PT1000 in 4-wire resistance mode.
It works in 2-wire resistance mode correctly, but in 4-wire mode it shows always 10.5 k!
The used test wiring is only 50 cm long. The real wiring lengh should be about 50 m.
So what can I do? What is wrong?
I have no ideas anymore.
Message 12 of 12
(874 Views)
