407 controller
hi
 i have similar kind of task where i need to send a signal,torque or displacement using labview program to mts 407 controller to control the actuator..any help from you how to do it and what all required for this..
Message 11 of 17
(1,873 Views)
You need to answer the same basic questions as the original poster. How are you planning to connect? If you have a controller with a serial interface, that would be the easiest.
Message 12 of 17
(1,870 Views)
its bnc connection, PCIe 6353 and SCB68 connector block i'm using to connect to mts..
now how do i send a signal to mts407 controller from labview program....and what all are the other things required in order to acheive this..
Message 13 of 17
(1,856 Views)
You use a DAQmx Write to send a signal. You don't mention what progamming language you are using but there are examples installed along with the driver. You'll have to study the manual to determine the type of signal - dc levels or some sort of waveform.
If you had chosen the the serial communication option for the controller, you would have had the advantage of using the existing example (assumimg you are using LabVIEW).
Message 14 of 17
(1,852 Views)
thanks a lot for your information..i'm using labview..i did bit of coding for signal acquisition but never had an experience in this kind of signal generation..so could you please help how do i send signal to the mts 407 controller..where do i find examples for this.
Message 15 of 17
(1,835 Views)
Examples have been in the same place for a very long time - Help>Find Examples. Dig down through Hardware Input and Output>DAQmx> Analog Generation.
Message 16 of 17
(1,830 Views)
Thanks for your info.. i found few examples
Message 17 of 17
(1,805 Views)
