50-pin I/O connector pinout for DAQPad- 6015
Hello. I have a DAQPad 6016 and also a DAQPad 6015 (USB). I want to know the pinout of the 50-pin I/O connector of the 6015. It seems that is the same for the two devices but I'm not sure (in fact, I guess that is the same for all of the E family). I looked for the information on manuals, on the installation CD, on the NI web, but I only got the pinout for the 32 pin- screw terminal.
Mónica
(3,285 Views)
Hello Mónica,
I believe that the DAQpad 6015 has a 68-pin connector.  If this is the case I believe you'll find the pin out you're looking for on page 10 or 11 of the NI DAQPad-6015/6016 Family Specifications Manual.
If this isn't what you're looking for it would be helpful if you can post back with a link to the product page from www.ni.com for the product you need the pin out for.
Have a great day!
Brooks
(3,276 Views)
Hello Mónica,
My apologies, after further research I've found the correct 50-pin pinout.  This manual is for the DAQpad 6016, but the "Full" pinout on page 3 is correct for the DAQpad 6015.  https://www.ni.com/docs/en-US/bundle/371402d/resource/371402d.pdf
Cheers,
Brooks
(3,265 Views)
