50103 on this simple VI?
Hi
I am using a PCI 6602 card and I am just trying to generate a continuous pulse train but I keep getting an error 50103 out of the start task.  Any idea why.  I don't get the error when I output to the counter on device 1 my e series board just the 6602.
(3,044 Views)
Chris,
A PCI-6602 should definitely be able to handle continuous pulse generation.  Just as a side note though, I would recommend using timing and error checking inside your while loops.  This will help to free up your processor resources.  I modified your code slightly and attached it to this post.
The error 50103 will occur if another program (perhaps even Measurement and Automation Explorer Test Panel) is running in the background.  Please be sure this is not the case.   The error could also occur if you are trying to run a DAQmx application after a Traditional DAQ application without first resetting the Traditional DAQ drivers.
KB: Error 50103 at DAQmx Start Task
The code that I attached works with my PCI-6602 so I would expect it to work with yours as well.  If you are still getting the error after considering my suggestions then please respond to this post and we can continue working on this issue.
Best Regards,
Jeff Tipps
(3,025 Views)
Here is my modified code:
Best of luck,
Jeff T.
(3,023 Views)
