01-15-2008 10:20 AM
01-16-2008 05:04 PM
Hello Jim
The error you are seeing is related to a known issue that affects similar DAQ cards being used under the 64-bit version of Vista with more than 2GB of RAM. How much RAM is your system using? This issue is currently being addressed, and I will let you know once it has been solved.
As another note, upgrading to DAQmx 8.6.1 will not fix this problem.
Your input would be greatly appreciated.
Chris_K
01-17-2008 09:29 AM
Thanks for your reply. The PC has 4 GB of RAM, possibly being upgraded to 8 GB. We would appreciate an update when the driver problem has been resolved. As a temporary fix should the problem worsen by not correcting itself when the PC is reboot, would using Windows boot flags to specify a maximum of 2 GB resolve the problem?
Jim Monte
01-18-2008
12:54 PM
- last edited on
06-27-2026
08:03 PM
by
Content Cleaner
Hi Jim
The problem has been addressed, fixed and it will be available in the next release of the DAQmx driver. I will post here as soon as it is available.
Please see the following KB for more information.
AE KB 4H8HN2QA: Receiving Error -50350 when using DAQmx on Vista x64
[broken link removed]
Chris_K_
01-18-2008
04:00 PM
- last edited on
06-27-2026
08:04 PM
by
Content Cleaner
Thanks. The link did not work, but I found the problem described at
http://digital.ni.com/public.nsf/allkb/3BCB832816FB32F7862573CB0082FA5E
01-28-2008
03:20 PM
- last edited on
06-27-2026
08:05 PM
by
Content Cleaner
Hi Jim, I just wanted to let you know that DAQmx 8.7 is now available.
http://joule.ni.com/nidu/cds/view/p/id/965/lang/en
01-29-2008
09:01 AM
- last edited on
06-27-2026
08:06 PM
by
Content Cleaner
Thanks. FYI, the link to the documentation did not seem to be present, and when I found the link through a search of NI's website, the name given for the installation file was different. The link I found for the documentation was
http://joule.ni.com/nidu/cds/view/p/id/977/lang/en
and the installation file was named DeviceDocumentation.exe
The link you gave had the instructions shown below for installation.
Perform the following steps to install NI-DAQmx:
Jim Monte
