+5V output dropout
My NI OEM USB-6211 when connected through its 50pin connector to a pcb board seems not be able to provide the +5V output anymore. The output provided voltage is about 1,5V instead of the declared +5V, without any analog or digital output activated on OEM USB-6211.
One possible explanation could be that the pcb board overloads the OEM USB-6211, even if theoretically the pcb board should require less than 50mA (the max current declared in the OEM USB-6211 specifications).
In order to check that my OEM USB-6211 is OK (not broken) and it is able to provide +5V output with a load of max 50mA I could connect the +5V output pin to DGND through a resistor (e.g. 100R). Decreasing the resistor value I should notice that OEM USB-6211 is not able to guarantee +5V anymore. Of course these test should be run without any other connected pc board. Does this test make sense or should I try differemtly?
Thanks.
(3,105 Views)
It is generally not a good idea to power circuits with the +5V line.  It is there mostly just to supply a pull up if needed.  I'd say if you can measure the +5V without the pcb board, the 6211 is fine.
Also, be careful because that 50mA limit is shared with the DIO lines as well.
(3,100 Views)
Thank you for the answer. That means I cannot use the +5V as supply for a pcb board connected to NI USB-6211.
How can I supply the pcb board? It needs +5V and -5V dual supply and less than 50mA current.
Is it possible to use some IC that "stabilize" the +5V before using it to supply the pcb board?
Thanks.
(3,086 Views)
