5V signal on unused channels
Hello everyone,
I am using a NI DAQ-Pad 6016 to measure analog voltages on all 8 differential channels. Every once in a while I will only use one or two channels. But when I do that I always get a 5V signal on the unused channels. Can anyone explain why that is?
With regards
Tobias
(3,163 Views)
Read this.
(3,158 Views)
It is simple enough, however, to ground channels that would otherwise be floating by simply shorting the positive and negative terminals of the channel.
That's written in the document I was supposed to read and I have already done this. Why do I still get the 5V signal?
(3,152 Views)
Shorting the positive and negative terminals together will only make them the same value.  This value is still floating in reference to GND.  I would tie them directly to GND since you are seeing this behavior.
Message Edited by rpursley8 on 01-26-2007 11:14 AM
Randall Pursley
(3,148 Views)
