6 Channel differential input multifunctional USB DAQ
Hey guys,
i'm looking for a multifunction DAQ like USB-6002 which i already have
https://www.ni.com/en-us/shop/model/usb-6002.html
but i need to measure 6 channels differential input.
Do you have any recommendation on a multifunctional DAQ?
(4,477 Views)
Perhaps the USB-6210 will work for you.
(4,456 Views)
If the budget allows it: Avoid multiplexing !
Have a look at the settletime error spec!
You haven't told us about your signal sources , needed accuracy and needed bandwidth ..
The USB 6356  or 7845R (small FPGA, migth need more thinking 😉 ) ??
Greetings from Germany
Henrik
LV since v3.1
(4,452 Views)
The USB-6210 seems perfect.
Thanks!
(4,428 Views)
I have 6 Channels and for each channel another GND.
So i measure 6 channels differential. Where do i connect the wires at the Pinout of the USB-6210?
(4,284 Views)
For AI0, AI8 is the negative side when configured as a differential channel.  AI1- = AI9, etc.
(4,281 Views)
That is the reason why those channels are very close to each other in the device pinout's.
(4,270 Views)
