60 second on 110 second off
hi i want to have accurate square pulse with 60 second ON and 110 second OFF the pulse which i made is some times more than 60 s and some times lesss even after try to work with DC %
Message 1 of 11
(3,985 Views)
duplicate post
Go to your original post and attach the code you have and define 'accurate'.
Message 2 of 11
(3,982 Views)
hi i attached my labview code in main discusion form
Message 3 of 11
(3,963 Views)
still no answer for my question?????/
Message 4 of 11
(3,945 Views)
Use a counter/timer to generate pulses and you will be able to accurately specify the high and low times. The timing will be determined by hardware clocks and not by software loop executions.
Message 5 of 11
(3,935 Views)
yes the main problem is that  i by opening S.w on PC the time will be change
?may i request you to send me some example on your solution ?
reagrds
jahangir
Message 6 of 11
(3,932 Views)
Look at the examples for pulse generation, then change them to match your hardware and timing requirements.
Message 7 of 11
(3,928 Views)
plese mention which example with link
regards
Message 8 of 11
(3,919 Views)
Start LabVIEW. From the Gettng Started window click Find Examples in the lower right. Double-click to expand : Hardware Input and Output, then DAQmx, then Generating Digital Pulses. Finally select "Generate Dig Pulse.vi" or "Generate Digital Pulse Train Continous.vi" depending on whether you want one pulse or a train. While you are there, study all the other examples, too. You can learn a lot from them, faster than waiting for replies in the forum.
Message 9 of 11
(3,916 Views)
Still not satisfied
Message 10 of 11
(3,900 Views)
