6001 AO control
Hello everyone. First of all, I am a student. And I'm new to labview. Your little help will be very helpful to me. I have a Ni 6001 data acquisition card. I want to control the speed and position of a hydraulic cylinder with this card.
I have the following products:
-proportional valves
-valve amplifiers ( rexroth VT-MRPA1-1-1X and VT-MRPA1-100-1X )
valve amplifiers are controlled with 0-10 volt input. (e.g 1v = 1mm 1.1v 2mm  10volt=10mm ) Can I do this using the 0-10 volt output on the Ni 6001 board?
(1,102 Views)
Accepted by topic author emre_
Yes, USB 6001 has 2 Analog Outputs that can drive +/-10V up to 5mA current
Santhosh
Soliton Technologies
(1,077 Views)
Thank you very much  for your interest and reply.🎉
(1,051 Views)
