6009: anti-aliasing filter
I'm using USB 6009 to measure acceleration at 1000 Hz. The acquired data seems to have aliasing components. Because the data sheet for 6009 does not mention anything about anti-aliasing filter, I guess USB6009 is a data acquisition system without AA filter. Is this correct?
Does anyone know a portable anti-aliasing filter suitable to be used with USB6009?
Thank you
(3,648 Views)
Greetings Tomato,
The 6009 does not have a custom anti-aliasing filter.  The analog input circuitry does include a MUX, amplifier, ADC, and FIFO, but does not include a user-configurable filter.  The AI circuit components have their own intrinsic frequency responses as well, but a 1kHz is well within the range of this device and its components.  Our S-Series cards, such as the NI 6115, do have built-in anti-aliasing filters that can be set in software to 50 and 500 kHz.
For more information on anti-aliasing filters and proper sampling rates, please refer to this KnowledgeBase:  Why Should I Use Anti-Aliasing Filters?
Nicholas B, National Instruments
(3,625 Views)
