6024E Continuous Acquistion
HI,
I'm trying to configure my card for continuous input reading with interrupts. A problem comes as in continuous mode it does not generate stop interrupts( or start). So How can I solve this? Thank you.
Thanks in advance.
Michael.
(3,637 Views)
Hi Michael,
The answer to what you are looking for could depend on quite a few different things.
What development environment are you using?  Are you using DAQmx or Traditional DAQ to generate the interrupts?  Which version of those drivers are you using?  Finally, you mentioned that you got it to work with finite acquisition.  Which commands were you using to get it to work in finite?
Thank you for the extra information,
(3,621 Views)
I am using LabVIEW 8.6 ,windows xp ,pci 6024e and SCB 68 connector. My application needs to take analog input at around 10 hertz frequency, then do some signal conditioning over the obtained signal. I have to send the processed signal through analog output channel.My application needs to have delay as small as possible. Can you plz tell me how to do it? can i find any readymade vi for my application.
thanks in advance.
(3,329 Views)
duplicate post
Post your question only once and do not hijack an unrelated thread.Smiley Mad
(3,323 Views)
