6052E: Read ADC at falling edge
Hi everybody!
I use a PCI6052E-Card and xPC target system.To control a ac-motor, I generate a 3phase-pwm signal, synchronized by a main clock. The pwm signals are symmetric. I use the falling edge of the main clock to do this. Now I would like to measure the current with a DCCT. To reduce the noise, I will trigger the measurement at the falling edge of the main clock.
Theres no driver for an xPC-system, so I need to program in C in Register Level. I know the DAQ examples. I have the DAQ-STC Reference and the PCI-E-Series Manual. In Simulink exist only one block to use the AD on a PCI6052 Card. I try to modify it, because I think it is a good basis.
I used the main clock as an (a) external convert signal, (b) an external convert&start signal (single wire acquisition) but I got nothing.
What I need is to to scan/sample the ADC for one time, every falling edge if my main clock.
René
(3,044 Views)
Hello René,
attached you’ll find all available resources for the Register Level Programming.
Measurement Hardware Driver Development Kit Register Level Programming Architecture
https://www.ni.com/en/support/documentation/supplemental/18/measurement-hardware-driver-development-...
Measurement Hardware Driver Development Kit Frequently Asked Questions
Kind regards
Ulrich
AE-NICER
(2,954 Views)
