6115 analog trigger problem
Hi all,
I have a PXI 6115 card, and I record a simple pulse, which lasts 20us. Following settings are used:
- sample Rate: 10MS/s (fastest with this card)
- range: +-10V
- trigger type: AnalogRefTrig. with 1000 presamples
- coupling: DC
- signal is between AI0- and AI0+, shielding on AI0GND
I can record the signal. There is a pulse from 0V to 4V, then back to 0V. My only problem is the trigger level, and I experienced something weird. -> if I set the trigger level to -1.9V, then there is no trigger
-> if I set the trigger level to 2V, there is a trigger sometimes, but only noise, so not my pulse
-> if I set the trigger level to to a value of 2.1 to 6V, then comes the trigger always.
It seems that I have a difference of 2V between the signal and the trigger level, although I use the internal triggering on the output on the PGIA. There is an unaccuracy of 78mV, I have read in the datasheet of the 6115. But where does the 2V come from? Any idea is welcome.
Mitulatbati
p.s. I have already tried the examples from NI.
(3,104 Views)
Hello Mitulatbati,
I discovered that you already posted the question in forum.
See the following link:
http://forums.ni.com/ni/board/message?board.id=180&message.id=41981&jump=true
I talked to my colleague and he told me, he’s still working on this issue.
He will post the answer in the forum, if any updates on information are available.
Ulrich
AE NICER
(3,087 Views)
