6133 DMA samples all zero
I have code (attached) derived from examples and past undocumented R&D for getting analog input data from the 6133 DAQ board via either register based I/O, or DMA. The register based I/O works. However, the DMA provides all zero samples. I would appreciate it if someone with more experience with the MHDDK can have a look at it.
Thanks.
Definitions used from outside the file provided are:
#define DAQ_SAMPLE_RATE 2000000
#define NUM_ADC_CHANNELS 2
#define ADC_RESOLUTION 14
#define END_OF_CONVERT_DELAY 17
#define SAMPLES_PER_REV 4000
#define NUM_CHANNELS 2
(3,496 Views)
Hi Sorterralee,
This the right place to ask for help on this subject: https://forums.ni.com/t5/Driver-Development-Kit-DDK/bd-p/90.
The forum is monitored by R&D according to this article: http://digital.ni.com/public.nsf/allkb/F4FEA84797FF1F2186256F6B005D8761.
(3,469 Views)
Thanks for that. I now have added the topic to that forum. I will leave it here also, in the hope that someone seeing either forum will have an answer soon.
(3,466 Views)
Accepted by topic author Sorterralee
The problem has been fixed by using the 64 bit versions of memory related functions mmap and mem_offset in osiUserCode for Neutrino 6.
(3,418 Views)
ie. The fix is done in the function below, found in nimhddk/QNXNeutrino6/osiUserCode.cpp. Refer to lines in "#if NI6133_DMA_USE_MEM64"
tDMAMemory * iBus::allocDMA (u32 size)
    void *virtualAddress;
    off64_t physicalAddress;
#else
    off_t physicalAddress;
#endif
    // Allocate DMA buffer
    virtualAddress = mmap64( 0, // set target 0 means that the system can put it anywhere it wants
#else
    virtualAddress = mmap( 0, // set target 0 means that the system can put it anywhere it wants
#endif
    size,
    PROT_READ|PROT_WRITE|PROT_NOCACHE, // Can read, write. Should not be cached.
    MAP_PHYS|MAP_ANON, // Dealing with physical memory. With MAP_ANON means physical contiguous memory is allocated (required for DMA buffer).
    NOFD, // fd
    0 ); // offset within shared memory. "Common to map in an entire shared object, in which case offset will be zero"
    if (virtualAddress == MAP_FAILED)
        munmap (virtualAddress, size);
        return NULL;
    // Get physical adddress
    if (mem_offset64( virtualAddress, NOFD, size, &physicalAddress, 0) == -1)
#else
    if (mem_offset( virtualAddress, NOFD, size, &physicalAddress, 0) == -1)
#endif
        return NULL;
    tDMAMemory *dma = new tDMAMemory (virtualAddress, physicalAddress, size);
    if (NULL == dma)
    return dma;
(3,403 Views)
