6134 - changing sampling rate dynamically
I would like to change the sampling rate of an analog input of pci6134 without stopping the task (acquisition). I am using an internal (onboard) clock as a timing source for AI. I have found a post on the forum that it should allow me to change the sampling rate dynamically by changing the clock frequency, however when I try to do that I get an error:
-200557: Measurements: Specified property cannot be set while the task is running.
Therefore, my questions are:
1. Is it possible to change the sampling rate during the acquisition (dynamically) S type of boards (6134 specifically)? or
2. Is there any other method to do that?
Thanks in advance
Andrzej
(3,578 Views)
Duplicate thread:
http://forums.ni.com/ni/board/message?board.id=40&thread.id=6961
Dennis Morini
District Sales Manager
National Instruments Denmark
http://www.ni.com/ask
(3,557 Views)
