6211 NI-DAQmx Base MAC OSX multiple analog output
I want to generate two simultaneous analog outputs on a NI USB-6211.
I'm using NI-DAQmx Base for Mac OS X v.3.4.0 in a Xcode 3.1.3 environment (in C) on a MacOSX 10.5 (intel). -- No Labview.
Using the provided example (contGeneration.c), I can get a sine wave with: "Dev1/ao0"
I do not get any ouput when creating a single task for "Dev1/ao0:1" as suggested in many threads on the subject.
How can I get the two analog outputs to work at the same time? Ideally, it would allow for the output to be different, and synchronized.
Thank you,
RT1
  // Task parameters
    int32       error = 0;
    TaskHandle  taskHandle = 0;
    int32       i = 0;
    char        errBuff[2048]={'\0'};
    time_t      startTime;
    bool32      done=0;
    // Channel parameters
    char        chan[] = "Dev1/ao0:1"; //****************************************************************
    float64     min = -10.0;
    float64     max = 10.0;
    // Timing parameters
    #define     bufferSize 512
    uInt64      samplesPerChan = bufferSize;
    float64     sampleRate = 10000.0;
    // Data write parameters
    float64     data[bufferSize];
    int32       pointsWritten;
    float64     timeout = 10.0;
    for(;i<bufferSize;i++)
        data[i] = 9.95*sin((double)i*2.0*PI/(double)bufferSize);
    DAQmxErrChk (DAQmxBaseCreateTask("",&taskHandle));
    DAQmxErrChk (DAQmxBaseCreateAOVoltageChan(taskHandle,chan,"",min,max,DAQmx_Val_Volts,NULL));
    DAQmxErrChk (DAQmxBaseCfgSampClkTiming(taskHandle,"",sampleRate,DAQmx_Val_Rising,DAQmx_Val_ContSamps,samplesPerChan));
    DAQmxErrChk (DAQmxBaseWriteAnalogF64(taskHandle,samplesPerChan,0,timeout,DAQmx_Val_GroupByChannel,data,&pointsWritten,NULL));
    DAQmxErrChk (DAQmxBaseStartTask(taskHandle));
    gRunning = 1;
    // The loop will quit after 10 seconds
    startTime = time(NULL);
    while( gRunning && !done && time(NULL)<startTime+10 ) {
        DAQmxErrChk (DAQmxBaseIsTaskDone(taskHandle,&done));
        if( !done )
            usleep(100000);
Error:
    if( DAQmxFailed(error) )
        DAQmxBaseGetExtendedErrorInfo(errBuff,2048);
    if( taskHandle!=0 ) {
        DAQmxBaseStopTask(taskHandle);
        DAQmxBaseClearTask(taskHandle);
printf ("DAQmxBase Error %d: %s\n", error, errBuff);
(3,080 Views)
Please ignore previous post.
RT1
(3,078 Views)
