6211 hardware
Hi All,
Instead of using the screw in type connector that came with the USB-6211, I would like to use a different type of connector (like crimping contact).
So I'd like to know the type of header that is mounted on the 6211's board so I could find the proper interface connector.
DP
(3,513 Views)
Here's the OEM manual for the USB-6211.  I think it has the information you're looking for.
http://www.ni.com/pdf/manuals/372083c.pdf
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(3,499 Views)
Accepted by topic author dphan128
Looked at the 6211OEM board? There's two ribbon connectors on there if that makes things easier for your application.
(3,479 Views)
