6221, AI current, External Shunt Resistor. Getting started with Swept Sine (SVT)
I am trying to read the current going through an RC (10kohms, 1 uF) circuit (connected to DAQ AO 0 outputing 2V, and to the AI O reading that voltage, and AI 1 reading the generated current).
The purpose is to use the getting started with Swept sine (from sound and vibration toolkit). Basically, it is doing impedance (or Z-meter, depending on how you call it).
Yet, on the DAQmx configuration, it says " external shunt resistor" with a Default value of 249. What does this mean, do I need to connect somehow a shunt resistor?
And this default value has a direct influence on the Nyquist diagram generated by this VI.
Please let me know if you have faced this issue already.
Kentmey.
Kentmey
(3,278 Views)
Kentmey,
How do you expect to measure the current?  The 6221 only measures voltage, so the simple way to get the current is to measure the voltage drop across a resistor.  The 249 ohm value is commonly used for measuring the current in 4-20 mA current loop systems.
If you are only looking at a series RC circuit and nothing else is connected, just measure the voltage at each end of the 10 kohm resistor.  The current is the difference divided by the resistance.
Lynn
(3,276 Views)
True 🙂
I though the DAQ could measure current too, which was confusing me.
Thanks, I'll try that soon 🙂
Kentmey
(3,269 Views)
