I've coded an RTX driver following the flow in example aiex1.cpp.  Setup for 7 channels.  Implemented all except I did not implement the aiGetScalingCoefficients.  Is it required?  What is it?
What changes are needed to setup for single ended common ground, instead of differential?  Is it necessary to have a voltage present on the 6224 during integration testing?
After initialization the JOINT_STATUS_2 returns 0x90 indicating that AI_Scan_In_Progress_St, and AI_EOC_St, and never clears.
Can't read from the FIFO unless the AI_Scan_In_Progress_St clears.
Since NI doesn't provide a manual I have no idea what this means, except that these flags never clear.
So where is the FIFO data?  Why are we using a FIFO.   Is there a mapped memory option instead?  I am not using DMA.
What exactly is flush call used in example code?  Are delays required between register commands?  Single stepping through the code gives the same JOINT_STATUS_2 status.
The example code calls write/read methods.  Does every write put zeros in non specific register bits?
Do you have a direct register accessing sequence with HEX inputs which shortcuts the labored methods used in the examples?  All I want is to read 7 analogs on demand at 100Hz.
Hope someone has answers.  Thanks.
(3,307 Views)
Hi lorenze -
It looks like you found the appropriate forum for your question later on.  We'll handle your post in this DDK thread.
David Staab, CLA
Staff Systems Engineer
(3,283 Views)
