6225 questions
1. Low-pass filter for PCI6225Is the low-pass filter for PCI6225 configurable or fixed?The User Manual for 622x states the following:  If the programmable filter is not enabled, the cutoff frequency is fixed at 750 kHz. If the cutoff is programmable, choose the lower cutoff to reduce measurement noise. (Page 52, section 4-4) However the spec for 6225 states that Small signal bandwidth (–3 dB)......700 kHz Please help confirm which one is correct. 2. AI Ground-Reference Setting for PCI6225In the User Manual for 622x, page 55, figure 4-3 gives an example where channels in the same device are configured with different AI Ground-Reference setting.In Figure 4-3, channel 0 is configured in differential mode, and channel 1 is configured in RSE mode.
I though the setting was global for device, which means that I could configure the board as either differential input or RSE/NRSE input type. Now the figure quoted seems to suggest that it’s possible to configure the channels in the same board as different type.
(3,165 Views)
Sorry the format of previous message is confusing. Here is it again:
I thought the setting was global for device, which means that I could configure the board as either differential input or RSE/NRSE input type. Now the figure quoted seems to suggest that it’s possible to configure the channels in the same board as different type. Is it possible?
(3,161 Views)
Glad to see you've already done some reading on the Manual. The 622x devices do not support a programmable filter on the AI. If it did it would list the filter cut-off like in the specfications of the 628x devices (which do support a programmable filter).
You can configure each channel to have a different ground reference, so you could read AI 0 differentially, ai 1 RSE and ai2 NRSE in the same task for example.  If you set up a task in MAX with multiple channels you can see that each can be setup with a different configuration (as long as the channel supports it).
Hope this helps,
Andrew S
(3,151 Views)
