6250 Trigger Channel
Hi
I am currently working on a 6250 board connected to a BNC2110.
Currently I am triggering at an analog voltage level at connector0 (would be channel 0).
Now I would like to trigger channel 3 (the 4th). I named the 6250 card slot3_.
Now when I set the trigger channel from slot3_0 to slot3_3 LabView tells me that this is not valid.
Is this a limitation of the 6250 board? In the data sheet I could find:
Number of triggers: 1
Source: AI0...15
(2,908 Views)
Please refer to the answer given here.
Jochen Klier
National Instruments Germany
(2,897 Views)
