64 bit library NIDAQmx.lib in a UNIX format ".a" ?
Currently in a software migration time, I have to compile a 64 bit application with a C++ IDE programming software (Embarcadero C++ builder 10.2). I found the files NIDAQmx.lib in a 32 and a 64 bit version under the installation directories: C:\Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\lib64(or lib32)\msvc\NIDAQmx.lib.
But, for a compilation on a 64 bit target platform, this IDE programming software is able to work only with a UNIX format of libraries with respectively,  an extension ".a" (replacement of ".lib" which works on 32 bit) to compile an executable for all platforms types.
So, after read a lot of posts about this topic, two solutions are available :
1. A first solution is to create manually a library 64 bit ".a" by a specific tool named MKEXP.exe (that is provided by embarcadero) but I need the source file(s) NIDAQmx.dll or ".def" that is not available under the respective installation directories of NI.Therefore, my request is, could-you provide us the source file ".dll" or where can I find it ? (standard solution when we are using external libraries...)
2. A second solution is, could you provide us directly a 64 library file with the extension ".a" or where can I find it?
For information, right now, we are working on Windows 10 - 64bit version and have to do a migration to 64 bit for approximately 60 stations with hardware acquisition boards from NI.
Please, let me know if you have any question?
S.Ruchet
(2,895 Views)
here is were you can find the location of the 64bit library:
Compile Linking Error 64-bit NI-DAQmx C Lib File Location - National Instruments
The 64bit lib is a native 64bit lib, there is no a file available.
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(2,853 Views)
The NIDAQmx.lib import library refers to entrypoints in the library "nicaiu.dll"[1], which is installed into the Windows System32 or SysWOW64 directories by the NI-DAQmx runtime installer. I don't know about the Embarcadero compiler, but I think this might be sufficient for your "mkexp" tool.
[1] Yes, this is not really an intuitive name, but unfortunately it can't change because of historic reasons.
(2,848 Views)
