6451 Digital Logic Level
I'm trying to set the digital logic level on my 6451.
I've tried setting the do logic family for each channel in the task but I get an error:
nidaqmx.errors.DaqError: Specified property is not supported by the device. Use the recommended Physical Channel property outside of the task instead.
Unsupported Property: DAQmx_DO_LogicFamily
Recommended Property: DAQmx_PhysicalChan_Dig_PortLogicFamily
I can't work out how to following this hint
I'm using the DAQmx driver in Python
Many Thanks
Nick
(1,357 Views)
Based on the specification, you can set the logic level for the whole port but not by channel.
Looks like the Python wrapper is NOT fully featured. Only related property I found is this,
Based on the docs, I see there is a constant but not support all values of 6451
Whereas on the LabVIEW side, I see a property to set the logic level,
Santhosh
Soliton Technologies
(1,350 Views)
Thanks for your answer.
I tried the power up state function but also got a "not supported on this device" error.
Immensely frustrating that the python API is not properly supported.
There is no chance we are using LabVIEW.
Is there someway I can call the DLL direct from python?
(1,336 Views)
Yes, you can call the C-dll directly in Python.
https://www.ni.com/en/support/documentation/supplemental/21/using-ni-daqmx-in-text-based-programming...
https://docs.python.org/3/library/ctypes.html
Please raise issues for these gaps at https://github.com/ni/nidaqmx-python/issues
Santhosh
(1,325 Views)
I'm not sure why I considered this as I really need both Windows and Linux support and I don't really want all that faff.
Unfortunately, this is gonna be a bit of a deal breaker for use of NI hardware I think.
Wild that they don't have really well featured python drivers.
Thanks for your help!
(1,322 Views)
