6509 - Read and Write c#
I have a problem with read implementation. I explain you.
I need to read EEprom and so: 3 pin (chipselect, DI, clock) set output mode and 1 set input (DO).
I initialize read port-pin:
private struct PortPinSettingRead
    public DigitalSingleChannelReader reader;
    public Task                       digitalInputReadTask;
    public UInt32                     pin;
PortPinSettingRead portPinSettingRead;
portPinSettingRead.digitalInputReadTask = new Task();
portPinSettingRead.digitalInputReadTask.DIChannels.CreateChannel("dev1/port11/line3", "", ChannelLineGrouping.OneChannelForEachLine);
portPinSettingRead.digitalInputReadTask.Control(TaskAction.Verify);
portPinSettingRead.reader = new DigitalSingleChannelReader(portPinSettingRead.digitalInputReadTask.Stream);
//READING
public int readDI(){
 try
      return portPinSettingRead.reader.ReadSingleSamplePortInt32();
 catch (Exception ex)
    System.Console.WriteLine(ex.Message);
    return -1;
I see by oscilloscope, that when I call readDI() function, the output pin go to 0.
Is it possible?
Thank you
(3,051 Views)
Hello chino5,
it's actually a strange behavior, but i would suggest you to try the DAQmx C# examples that you can find into C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DotNET4.5.1\Digital
Do you notice the same behavior?
(2,997 Views)
