6713 connector block
What are the connector blocks that are compatible with the PXI-6713 analog output card? I know the SCB-68 is compatible, but I'm wondering if any of the TB- series connector blocks are.
(2,903 Views)
Hi akeshet,
From what I can tell there are several compatible terminal blocks that can be used with the PXI-6713.  Here is a list of the most common choices:
TB-2705 - Shielded, No Cable Required
BNC-2110 - Shielded
SCB-68 - Shielded
TBX-68 - Unshielded
CB-68LP - Unshielded
Hope this helps.
Jared T.
(2,885 Views)
