8 channel data aquisation
Dear sir,
I malisetty sudheer wrote a mail yesterday regarding 8 channel analog data acquisation.please send the .c file,.uir file and .h file file if u are fifnished with the programme so that i can check and i can make some ammndments if necessary.again i am stating the question please go through the question.
1)to get 8 channel analog data acquisation at a time when pressed aquire button on the uir pannel. and to be displayed on the graph with 8 signals in different colours.
2)with one channel having trigger option.
3)to store the data of the signals in text file when pressed save button from channel 1 ,channe2........,channel 7,channel 8.so that we have already programs in matlab so simulate the data.
i am sending the example which i got from cvi 7.0i want to modify that programme. if u suggest to go through other process i will try to do in that.i request u for your help regarding my problem.i will be waiting for your valuable and favourable reply.the device is daq 6259.we are using labwindows with ni-daqmx drivers.
Thanking you,
yours sincerely,
m.sudheer
Message 1 of 1
(2,913 Views)
