9161 VS 9162 Any difference
Seems not much documents for them.
(4,252 Views)
Hi Turbot,
Thanks for the post and I hope your well today.
I have no forgotten about the post you've made here: Does the polling fast enough.
Please don't post multiple times for the same issue. I will continue to support you in the main thread.
However, the answers your looking for can be found in this KnowledgeBase Article:
Why Does My USB DAQ Module Get the "Unable to Locate a Driver" Error?
http://digital.ni.com/public.nsf/allkb/42702DA4B800C73586257273006504B3
Most C Series modules work with NI-DAQmx running on Windows.  The two exceptions are the NI USB-9211 and the NI USB-9215, which originally used the USB carrier, USB-9161.  These model numbers are used when the modules are used in a USB-9161.  When used in this configuration, DAQmx Base is required, as DAQmx will not recognize the units.
The difference between the USB-9161 and USB-9162 is that the USB-9161 works only with NI-DAQmx Base 2.2 or older.
Hope this helps,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(4,248 Views)
Is there any memory or FIFO on 916x, or on 9229.
Need to garentee no data lost in the polling by the PC.
(4,244 Views)
Hi Turbot,
Thanks for the reply.
As stated previously, I have replied to your previous question and this new one in the original thread
http://forums.ni.com/ni/board/message?board.id=250&message.id=45546#M45546
Kind Regards
James Hillman
(4,242 Views)
