buen día necesito integrar 9 señales a 2 dispositivos NI cDAQ-9181, es posible tener los 2 dispositivos trabajando en una misma pc?, hay algun problema para escribir los registros a la misma base de datos de SQL.
mourning, i need to integrate nine signals, for 2 hardware NI cDAQ-9181, you can have 2 devices working on the same pc?, if it be true, that there is a problem to write the records to the same SQL database.
(3,783 Views)
Hello PABEL,
There should be no problem using multiple ethernet cDAQ devices with the same computer, so long as the bandwidth of the network is enough to handle the ammount of data that would be sent, which is ussually not a problem with cDAQ devices.
Using the same SQL database for different for the data vcoming from different devices wouldn't be a possible, and it would mostly be an issue of handling the data in the way you want.
Also if you wish to get support in spanish I'd advice you to go to our spanish section in the forums, in there you can post the question in spanish and expect an answer in spanish as well, so please keep this are of the forums for english posts.
Cheers,
(3,765 Views)
