9191 Not showing Wireless Settings in MAX
I have a new 9191 chassis that I am trying to set up. I have a fresh install of DAQmx 9.9 on a Windows 7-64 Bit laptop. The 9191 is currently hard wired to the network.
MAX finds the chassis, but there are no configuration settings for wlan0:
Trying to add the device is met with the error:
"Add device has failed. The error report from the device driver is as follows:
Add Device -201039
Object lacks a required property.
Add the required property to the object.
Propert: TCPIP.WirelssIP
Property: TCPIP.WirelessMac
The same result is met when trying to add the device from the network browser or web interface. I am able to ping the deice with no issues. I have tried update to the latest firmware (1.5) as well as several full device resets to no avail. I have also had the same problem running DAQmx 9.8 on another machine.
Help!
Message 1 of 9
(5,643 Views)
Hi zturner,
On the Firmware tab for the device, what is listed as the Current firmware version?  Just wanting to double-check that 1.5 was successfully applied ...
On the device itself, how are the LEDs behaving?
Can you provide a screenshot of your laptop's IP config?  Have you tried making a direct connection between the device and PC, rather than through the network?
Message 2 of 9
(5,591 Views)
Kyle,
The current firmware version is 1.5.1f0.
With the device powered up and connected via ethernet, I have a solid green power lamp and no other active .
Connecting the device directly to my PC will discover the device with the "Find Network Device" utility, but I get the following error when I try to add the device:
Message 3 of 9
(5,484 Views)
Sounds like the device is presenting some defect.  We probably ought to open an RMA request, so we can inspect the hardware.  I'll send you a PM with further instruction.
Message 4 of 9
(5,479 Views)
Kyle,
I've also downgraded to firmware 1.2 just to see if it was a firmware issue. No luck.
I'll await your RMA instructions via PM, thanks.
Message 5 of 9
(5,477 Views)
Hello, I have absolutely the same problem with ni cDAQ-9191 device. I don’t see any fields for wireless settings and I see the same errors. Have you found the solution for this?
Thank you,
Misha.
Message 6 of 9
(4,612 Views)
The Problem fixed! Thank you!
Message 7 of 9
(4,605 Views)
My unit had to be returned and replaced under warranty. The comments said something about a hardware failure, but they were not specific.
Message 8 of 9
(4,602 Views)
Hi Ztuner, in my case the problem was in Wi-Fi module inside cDAQ-9191. I dont know how and what the reason, but after a lot of times trying to find Wi-Fi Adapter in MAXI desided to disassembled cDAQ-9191 and discovered, that Wi-Fi module was out of slot. It was a little bit displasement. Very strange. No blow, no falls. Now all fine.
Message 9 of 9
(4,599 Views)
