9205 not recognised
I have a 9072 cDAQ chassis and four 9205 voltage modules. When I power it up only one of the 9205 modules is recognised in Measurement and Automation Explorer v5.0. The module that is recognised works in all slots while the modules that are not recognised do not work in any of the slots. Are my 9205 modules dead? Is there any way that I can check them out? Any help would be very appreciated!
(3,616 Views)
Hi MunnB,
That sounds like quite an interesting issue you have. Other than swapping the cards round within the Chassis, what other troubleshooting steps have you taken??
If you have access to any other cRIO or DAQ chassis, could you try the Modules there instead?
There is a potential that there may be a more serious issue, but to be sure, could you try and repair or reinstall the drivers you have for the product? Follow this link if you are unsure:
http://digital.ni.com/public.nsf/allkb/AC6ED75D3D93375686256E8E00245F0D?OpenDocument
They can be downloaded from the NI website if necessary from this link http://www.ni.com/downloads/
After that it may be worth phoning NI and asking to put your cards through for RMA.
Nathan
National Instruments UK & Ireland
(3,608 Views)
Thanks Nathan,
I have no other hardware to try the cards out on and the Measurement and Automation software is a fresh install.
I think that I will go down the RMA route.
Rob
(3,592 Views)
