9205 showing error and unstability (please help me out)
hello!!!
i am using 9205 module for measuring output voltage from heat flux sensors. the output voltage is in range of millivolts but 9205 is not responding accurately to these sensors. i did some test to check wether 9205 is functioning correct or not.
i connected a voltage source with 9205 and did a parallel connection to 9219 also which works perfectly with sensors (but there are only 4 channels)
but there is difference in values of both the device at millivolt range.
here is some samples from recorded data..
time     NI 9205     NI 9219
0 sec   0.150856   0.138406
1 sec   0.194878   0.138556
2 sec   0.192250   0.138232
3 sec   0.170239   0.157739
4 sec   0.197506   0.173728
5 sec   0.244157   0.186964
6 sec   0.224445   0.188802
7 sec   0.207362   0.203102
8 sec   0.250070   0.211435
9 sec   0.276516   0.221425
10sec  0.265182   0.235680
please help me out and tell me
wether 9205 is working correctly or it has some problem.??
(3,331 Views)
You may be experiencing some noise artifacts on the 9205.  The 9205 does not have channel-to-channel isolation and requires a ground reference.  Have you seen this Knowledge Base?
Noisy Readings on the NI 9205:
http://digital.ni.com/public.nsf/allkb/62F7C1C5DD187E58862576B200700323
(3,244 Views)
