9205 trigger
why my signal moves happens over time when it is a trigger (hardware use ni9172 ni9205)
Message 1 of 9
(5,166 Views)
Can you give us more details about your problem (soft version, what are you doing, ...)?
    Benjamin R.
Senior LabVIEW Developer @Neosoft
Message 2 of 9
(5,138 Views)
I use the version 8.5de LV
my problem is that the declenchement does only once at the launch of the stain. in fact I wish he starts at each loop (while)
I find a solution (VI attachment), but I find it too slow
Message 3 of 9
(5,127 Views)
Hi julien03,
When you commit a task that uses analog triggers on the NI 9205, NI-DAQmx delays to allow the NI 9205's trigger circuitry to settle. To speed up your second VI by moving this delay outside the loop, you can use DAQmx Control Task.vi to commit the task outside the loop. One of the examples that ships with NI-DAQmx demonstrates this: Acq&Graph Voltage-Int Clk-HW Trig Restarts.vi.
Brad
Brad Keryan
NI R&D
Message 4 of 9
(5,121 Views)
You also have an example here to know how to use Control Task VI.
    Benjamin R.
Message 5 of 9
(5,112 Views)
Hi.
my problem is not the frequency of sampling but time loop while, too slow. I lost precision.
Message 6 of 9
(5,103 Views)
To increase your time loop put out of your While Loop the Start and Stop Task VIs. Then your time loop will your Sample Clock Rate dependent.
    Benjamin R.
Message 7 of 9
(5,092 Views)
it would be possible to have an example
Message 8 of 9
(5,087 Views)
Here you have a picture about what I described above.
Message Edité par BenjaminR le 05-20-2008 10:56 AM
    Benjamin R.
Message 9 of 9
(5,078 Views)
