9213 Alternative Connector
I have several NI-9213, 16-channel TC modules and the spring terminal connector is unacceptable for my application.  Is there an alternate connector similar to the TB-9212 with MiniTC connector.  I would like to be able to use the easy plug in style TC connections.
Any suggestions would be greatly appreciated.
Thank you!
Certified LabVIEW Architect since 2007
(1,256 Views)
Unfortunately, no MiniTC connector breakout board is available for 9213. Probably, someone needs to create one.
Santhosh
Soliton Technologies
(1,228 Views)
