9215 voltage railing
Hello I just bought a NI 9215 and I am testing and prototyping on the cDAQ 9172 while I wait for my 9075 to arrive. I also have the 9411 for reading in a TTL pulse coming from an anemometer.
The 9215 is reading the following voltages
3  0-5VDC
These signals each require a 5V excitation source which I am providing from the source lugs on the 9411 and feeding in 12VDC  to the power connector.
I have everything wired correctly, on the 9411 and I am getting power to my sensors, however, when I run the test panels in the express DAQ assistant, I am seeing all 3 channels railing between -10 and 10....on my scaled units, the front panel all the readings are railing min to max....I tried connecting the AI- to the COM on all 3 channels and this did not help.
Am I missing something?
Steven
Steven Howell
Controls and Instrumentation Engineer
Jacobs Technologies
NASA Johnson Space Center
(3,128 Views)
Hello Steven,
Please try to connect power from NI 9411 module directly to NI 9215 module (COM to AI0- and +5V to AI0+) and tell we if you see 5V - to eliminate hardware problems.
Gregor Cerne
(3,119 Views)
thanks for the reply Gregor, I was looking again this morning, and believe I dont have a true ground reference, I am going to tie the COM terminal to building ground and see if that resolves the issue, also since my sensors are not providing much of a load to the signal, I may need to put resistors in line with the sensor to ground.
Steven Howell
Jacobs Technologies
(3,104 Views)
