9215 wire connection for single ended voltage signal
From the NI9215 operating instruction and specification file, I have learnt about the following:
Connecting Single-Ended Voltage Signals to the
NI 9215
To connect single-ended voltage signals to the NI 9215 with screw
terminal, yo
u must also connect the ground signal to the COM
terminal to keep the common-mode voltage in the specified range
I am doing a swept sine measurement and the terminal that I am going to connect to the NI 9215 is single ended. May I know if it is compulsory to make the connection from ground signal to the COM terminal? how will it affect my swept sine measurement?
Thank you.
(3,121 Views)
You should read this article and have a look at Table 1:
Field Wiring and Noise Considerations for Analog Signals
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,111 Views)
