9235 module with ENET-9163 chassis
can I use a 9235 (strain gage quarter bridge) module with an old ENET-9163 chassis?
Is there any downside respect using the module with a new 9188 chassis?
Thank you so much.
(3,022 Views)
Hello Roberto,
The 9235 is not supported in the 9163 carrier.  You can see a full list of the modules that the 9163 supports in this document
-Jeff
(3,019 Views)
Hi Roberto-
To add to Jeff's response, no, there isn't any particular downside of using any supported C Series module in any of the current generation cDAQ chassis (as of the date of this post, all module support is consistent across cDAQ chassis except for the cDAQ-9172, regardless of bus).
If you get a chance to try out a cDAQ-9188 (or cDAQ-9181 or cDAQ-9191, depending on your needs on bus and number of slots) and have any particular problems, please feel free to post to this forum for advice. Smiley Happy
Tom W
(3,015 Views)
