A/D NI USB-6008 problem
i use A/D NI USB-6008 in automatic station i heve several units that stop blinking and dos not work if i replace the unit the station start to work correctly can you advice me what the problem thank you
(4,054 Views)
Hello Nissimg,
What is the station you are using?  How do you have your USB set-up?  Was it working initially?  If so, did anything change to prompt it no longer working as expected?  What behavior are you expecting?
Best wishes!
Amanda B.
(4,035 Views)
