A multiplexer vi.
Hello all,
I am totally surprised at the fact that there is no such thing as a multiplexer/demux express/sub vi in labview 7 express. I actually need demux code in labview.
I hope somebody has some suggestions for fast demux vi code.
I tried using a case structure, but as far as I could test it, it will not work (to even configure it as a demux causes errors!).
Thanks in advance.
(3,223 Views)
Depending on how the data is coming in I would suggest using the decimate array function. It is an easy way to split an array into a bunch of sub arrays, and I think would solve your problem.
If not can you attach the VI with the case structures that caused errors.
(3,223 Views)
