A signal generated at NI USB 6211 is appearing at analog input. It's a fault?
I'm generating a sound signal at analog output A0 or A1 and the signal is appearing at input analog. This a internal fault ou I need use a coaxial cable to stop this contamination?
(3,988 Views)
Could you please explain better what is going on? When you created the task for your board, did it work?
I'm sending to you some code examples for your board.
http://zone.ni.com/devzone/cda/epd/p/id/6209
If you have any doubt please contact me.
Thanks.
Best Regards
Luciano Borges
Test Development Engineer
(3,962 Views)
I'm using a 6211 card and LabView version 8.5.
At AO 0 analog output I'm generating a sound signal of 5 kHz and using a sampling rate of 40 KHz.  In the AI1 and AI3 digital inputs I'm reading the signal received by two microphones at a sampling rate of 40 KHz too.
The signal read at AI1 seems right and is decreased when the volume is also decreased, but the signal read on the AI3 remains unchanged even when the sound is off.
There is a drain of the analog output signal to the analog input?
In a discussion here on ufmg were raised the following questions:
1) This card (6211) uses more than one multiplexer? If so would like to know which ports are connected to each of the multiplexes?
2) Would be a solution to connect the generation to the multiplexer and the reception to another multiplexer if more than one?
3) Another solution would be to short circuit the analog inputs are not used to discharge the capacitor input? This can be done?
4) There is a another VI s for LabView 8.5?
Thank you..
(3,933 Views)
Olá,
Verifiquei em seu cadastro que você é brasileiro então podemos continuar em português.
Esta placa possui apenas um multiplexador para todos os canais de entrada analógica. Portanto, a taxa máxima de aquisição de dados para esta placa (250 KS/s) é dividida quando se utiliza mais de um canal.
Você já testou outras entradas analógicas para ver se o comportamente é o mesmo? Isso acontece no canal 3, apenas quando o canal 1 também está fazendo aquisição? Ou caso apenas o canal 3 esteja fazendo a aquisição dos dados isso também ocorre? Quando você faz a aquisição em mais de 2 canais, o que acontece com os demais?
Você gostaria de um exemplo de VI que fizesse o que no LabVIEW?
Obrigado.
Atenciosamente,
Luciano Borges
(3,894 Views)
Accepted by topic author renegia
Oi Luciano,
com respeito a interferência do sinal gerado (saída analógica) no sinal lido (entrada analógica) hoje não houve interferência.
Apliquei o sinal gerado e lido em um oscilócopio e ambos estão corretos..
Qualquer assunto te mandarei novas questões. Obrigado..
(3,876 Views)
