AD Module
I'm a bit confused about using the PXI-6133 analog input as an A/D module because when I  read about it I found it has an A/D in its channel construction, so now can consider the output of this module as a digital form. BTW when I run, it showed me an analog signal.
Message 1 of 1
(1,273 Views)
