AI config.vi question
Hello, I recently installed labview 5.1 to a computer that has a PCI 6035E card also installed into the computer. I downloaded NIDAQ 7.1 as my driver. When I try to open my labview program also written in 5.1 I get a prompt to find file AI Config.vi. I cannot find this file on the computer I installed 5.1 or my currently working system that also has 5.1. Any suggestions? I am just really confused as to how to know that labview and daq are recognizing each other and that the driver is compatible with the system. I guess that is basically another question of mine. Thanks everyone
Bigred
(2,805 Views)
Hi bigred, NI-DAQ 7.1 doesn't ship with VIs that are compatible with LabVIEW 5.1. You'll need to go back to an older NI-DAQ version for this. I think NI-DAQ 6.9.3 has LabVIEW 5.1 VIs, so you can go back to that version, unless you want to upgrade to a newer LabVIEW version.
Joe
(2,802 Views)
