AO Voltage Reading with PCIe-7856
Hello! I am trying to control and collect data from a potentiometer with the PCIe-7856 and SCB-68 terminal block.
Currently, the poteniometer is not wired up to the terminal block. My problem is that I use my labview FPGA I/O vi to send, for example, 1 V to AO3/AO3GND but with a multimeter I am measuring a response of 10.18V. When I send 0 V with the vi, the voltmeter will read 0.00 V. Any voltage that I try to send greater than 0 results in a voltmeter reading of 10 V.
I ran the self-test for the PCIe in MAX and it came out okay. Could this be a problem with the labview vi that I am using?
Thank you!
Message 1 of 1
(845 Views)
