AO does not work after installing drivers 7.5 for USB 6008
I have checked the AO with a shipped with DAQmx Base drivers and it worked. Then I have installed drivers 7.5 and used NI-DAQmx Base to NI-DAQmx Conversion Utility Version 1.0 Beta. And now this program does not work.
When I checked it in a MAX inside My VI Logger Task I have found that it does not work as well. In both cases it does not show any error it just does not change voltage value.
Are there some suggestion?
Thanks. Sergey.
(3,230 Views)
Looks like I found the problem.
It appears that AO does not work. I have checked the program with another USB 6008 on the same PC and it works.
Is there a way to check it for sure that AO does not work?
(3,213 Views)
 In Measurement and Automation explorer, find the device, and go to the test panels. Switch to voltage output, and set a voltage checking it with a DMM. If that doesn't work, then it looks like the AO circuitry is possible faulty. If this is the case you'll need to call into techincal support in the country where you bought the product (in the UK that's 01635 572410) to initiate a returns procedure for this unit.
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(3,203 Views)
Thanks Sacha for your responce.
I did check of it in NI and results it the same, I can adjust voltage in a MAX but it does not change when I check it with multimeter.
I'll ask my boss to start replacement procedure.
Sergey.
(3,199 Views)
