AO output
Dear Sir,
In my PCI6221 two DAC channel available but for sine wave output i can get only one o/p at a time. So is it possible
to get both output at time ? If yes how ?
The above result is obtained using measurement & automation software.
Best Regards,
Jagdish
(2,916 Views)
Hi Jagdish,
The MAX test panel doesn't offer complete functionality for the devices. If you want to use all capabilities of your device you should write your own application.
- George -
(2,889 Views)
thanks.
I have one more query plz help if possible ?
I want to log adc value wrt to real time clock in text or excel format how i can proceed ?
(2,877 Views)
If you're using daqmx c, then you should write a simple method that converts float data to text and then writes it to a csv file. If you're using Labview, you may can use SignalExpress for this task.
- George -
(2,874 Views)
