AO then AI with LabVIEW
What I need to do - using a PCI-1611E - is output an analog waveform for a ceratin length of time, wait, and then read in an anolog signal. The system needs to work in the millisecond ranges, and the triggering needs to be detailed. If anybody can give me an idea of how to go about this I would be most grateful.
(2,756 Views)
NI does not have a PCI-1611E board. I would suggest that you correct the board's information to get precise feedback.
(2,756 Views)
The actual device is part of the e-series range, it is a PCI version hence the specification of PCI - you'll find it under NI 6111E - I'm afraid my fingers ran away with my typing before. Also the manual that ships with it describes it as a PCI-6111E. The other information I should have mentioned was that I'm using LabVIEW to program my application.
(2,756 Views)
