APFI0 vs. AI connections for analog triggering with PCI-6250
NI:
- Application: My application employs a silicon photomultiplier (low light) detector that outputs brief (order of nsec) and low amplitude (5mV-1.5V) analog pulses. Please note that I can add an RC-circuit to widen the duration of the pulses if necessary (ie: don't worry about that).  I need to use an analog trigger to count these pulses.  I think that this program called "DAQmx: Counting Non-TTL Pulses with Multifunction Board and Labview" nearly fits my project description.
- Questions: Should I use the APFI0 or an analog input channel to acquire this signal?  What are the functional differences in these channels? What is the input range of the APFI0 (+/- 10V?) and can it be adjusted to +/- 2V?  I WOULD just try both and see which one works, but my boss wanted to save money by buying the 64-pin backshell to create a custom 64 pin cable (solder the center conductor of a coaxial cable directly to the pin of the custom cable kit).  Which channel provides the most flexible configuration?  Please note that this is a ground-referenced signal.
- Equipment: M-series PCI-6250 DAQ, LabView 7.1, Windows XP, 64-pin custom cable backshell, RG-58C coaxial cable
thank you,
-Dave
(3,578 Views)
I would recommend the AI channel. If you check ouf figure 11-2 in the M-series manual you'll see that the APFI line does not go through the amplifier os it will always be at a +/-10 V range. The AI channel will be amplified (assuming you set the AI Max/Min to +/-2 V. That section also details some of the limits of this but with just a singe channel the AI channel is the way to go.
Hope this helps,
Andrew S
(3,556 Views)
