Accuracy of NI X Series Multifunction Data Acquisition
I'm learning to calculate the measurement accuracy from NI USB 6341 data acquisition.
The data sheet shows a example, but I can not get to that result.
My estimate is 2,3 mV and don´t 2,19 uV like the data sheet,
can somebody tell me the error?
and
Where i can find  data acquisition with more accuracy?
(2,851 Views)
The data sheet example results in ~2e3 uV.  Did you possibly confuse the U.S. usage of "." as a decimal point with the "," which apperently you use?  In the data sheet the figure "AbsoluteAccuracy = 2,190 μV" refers to 2 thousand 1 hundred and 90 microvolts which is close to your 2 and 3/10 millivolts.
Lynn
(2,849 Views)
